Cyclic symmetry setup in NX Nastran
I setup a rotational cyclic symmetry modal analysis run in NX nastran following the guidelines in the user manual. I can't make sense of the results. In F06 file, it gives a separate eigenvalue block for each harmonics starting from 0. I was hoping that Nastran would assemble solutions from all harmonics into a single solution set that would have been found if the full model was analyzed. Does anybody have experience with this?
-Ali
-Ali
