analysis results Patran/Nastran are not out
hello,I new to work with msc Patran/nastran.
i have problem with the analysis result:when analyses are finish the result are not out,please help me
RE: analysis results Patran/Nastran are not out
you have to import you results into patran : analysis / access results / Read OP2 or attach xdb
click, select resuts file OK
then apply
