band analysis in nx 8.5
Hello nx supportteam,
I'm looking for assembly clearance analysis, like band analysis in V5,
the distance between the to sets has a color scale. Look attached pictures.
Is there a way to get this , do this in nx ?
sorry new in NX
regards
Erwin
RE: band analysis in nx 8.5
sorry new in NX
regards
Erwin
To set up a 'Clearance Set' go to...
Analysis -> Assembly Clearance -> Clearance Set -> New...
...and when the dialog opens you will see a field to define the 'Clearance Zone'. If you hit the 'F1' key you'll get the help files which will explain how to use the various options, including 'Clearance Zones', as well as how to select what components go into what 'Clearance Set'.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I will give it a try,
sorry new in NX
regards
Erwin
I'm looking for the distance coloring I have in V5.
sorry new in NX
regards
Erwin
Analysis>Deviation>Gauge...
Khimani Mohiki
Design Engineer - Aston Martin
NX8.5
