How to calculate the value of ks
In order to do the structural analysis for square and Rectangular footings I first calculate ks using equations from reference #2. I recently came across Reference #1 which provides some extra verbage and a different equation for rectangular footings than reference #2. What is the recommended approach (Bowles or Das) to follow absent equations provided in a geotechnical report?
Reference 1: Foundation Analysis & Design 5th Ed page 502 (Joseph Bowles).
Reference 2: of Foundation Engineering 5th Ed page 277 (Braja Das).
Terzaghi proposed that ks for full-sized footings could be obtained from plate-load tests using the following equations:
For footings on clay
ks= k1 *(B1/B) (9-3 Reff #1) (6.46 Reff #2)
For footings on sand:
ks= k1 ((B+B1)/2B)2 (9-4 Reff #1) (6.48 Reff #2)
In these two equations use B1 = side dimension of the square base used in the load test to
Produce k1. In most cases B1 is 1 ft, but whatever B1 dimension was used should be input.
Extra verbiage from Reference #1:
“Also this equation deteriorates when B/B1 > 3.” (Pertaining to the two ks equations for sand or clay.)
“Equations (9-3), (9-4), and (9-5) are presented primarily for historical purposes and are not recommended by the author for general use.”
Different equation from Reference #1:
For a rectangular footing with dimensions of B X L with m = L/B,
ks= k1 (m+0.5)/1.5m (9-5 Reff #1)
ks= k(BxB) *(1+0.5(B/L))/1.5 (6.49 Reff #2)
ks is the desired value of modulus of subgrade reaction for the full-size foundation
k1is the value obtained from a plate-load test using a 1ft X 1ft or other size load plate.
