Hydraulic Cutting Forces
Can anyone tell me how to calculate the hydraulic cylinder diameter requred to cut steel plate using a shear tool operated from a hydraulic power pack.
RE: Hydraulic Cutting Forces
First you'll have to find the shear strength of the thickness and type of steel you're trying to cut (material engineering). Then we need to know the pressure of your particular power pack.
Thanks for your reply but I am looking for a calculation method or general formula so I can calculate for general tool design.
Generaly using Mild steel at 1000psi to 1500psi.
To start to solve this relatively simple problem, you should draw a model of your process showing the tool and the workpiece in their initial and final positions. Then, you calculate the energy required to reach the final position, then, knowing the process velocity, you can easily calculate the force needed to deliver this energy at the required speed. This is as simple as that.
Viktor
http://viktorastakhov.tripod.com
Multiply the perimeter, P, of the cut piece by the material thickness,t, to get the area to be blanked. Multiply this by 0.8 (to get the shear strength for mild steel only) x ultimate tensile strength for mild steel (approximately 60,000 psi) to get the force required.
So, P x t x 0.8 x 60,000 = force
Since area = force/pressure and area = (pi x diameter^2)/4, then
Diameter = sqrt[(4 x force)/(pi x pressure)]
Also allow yourself a factor of safety of 1.5 or more in your force calculations.
