Units to be used in structural analysis
Hi
I am confused with units in a structural analysis. I have modelled the geometry in mm (keypoints selected assuming mm dimensions).
It is a tube subjected to internal pressure.
I need to apply the following loads and get deflection in mm? What are the units I should follow?
1) Youngs Modulus
2) Density
3) Gravity (Unit of acceleration)
4) Internal pressure
5) External force.
6) Thermal expansion
7) Thermal conductivity
Pls help
1) Youngs Modulus
2) Density
5) External force.
Pls help
RE: Units to be used in structural analysis
If you work in mm, just be sure you units are consistent, i.e :
1) MPa
2) kg.mm-3
3) kg.mm.s-2
4) MPa
5) N
For thermal units, I don't remember them, but as for structural ones, check that they are consistent.
But, i think , for point 3, the unit is wrong..
Should i specify gravity in 9.81m/s2 or 9810 mm/s2
Pls confirm
Can you also specify why density needs to be in kg/mm3 where as all other items are in N, MPa etc.
Or is it shall be in N/mm3
Reply pls.
Thanks a lot.
For density, simply because a density is in kg/mm3, so that if you multiply it by the volume of your body you get your mass.
