Using any software design and stimulate "Plate with Center Hole, crack on hole"
I need help in drawing and stimulating "Plate with Center Hole, crack on hole".
Then stimulate it and get Stress and displacement constraints to find K1(stress intensity factor)
Assume any values for crack length and plate length and all... Plate is under plane strain condition.
Image is attached.
Please help me its kind of urgent :) Thanks a lot.
RE: Using any software design and stimulate "Plate with Center Hole, crack on hole"
No need to model it as the answer can be found in any text book. Just hand in your homework and refer the teacher to that book.
@Corus can you please tell me any book which has this in it .
