Surface normal display in SolidWorks 2012
new user, coming from RhinoCAD 5....in Rhino, surface normals and inside/outside of a surface can be displayed by different colors and little arrows that display the overall normal direction of the surface when you click on it. It also allows you to flip the direction.
Is there a similar setting/functionality in SolidWorks 2012 that can be used to check surfaces or solid model outer surfaces for normal direction and change the direction?
RE: Surface normal display in SolidWorks 2012
Try:
View/Display/Zebra Stripes (or Curvature).
Or right-click on face, Zebra Stripes.
As close as I know what you are looking for.
Chris, CSWA
SolidWorks 13
ctopher's home
SolidWorks Legion
