Spread Footing - Punching Shear
For a concentric spread footing, when checking punching shear capacity against Vu how should Vu be calculated. I have always done (and seen in examples) as taking the ultimate pressure, qu, multiplied by the footing area minus the area within Bo. I am wondering why I can't take the full projection of 'd' on each side of the column instead of d/2 for the Vu. Is Vu = qu x (F_area - (c+d)^2) or can it be Vu = qu x (F_area - (2c+d)^2)? I realize that the failure plane is taken at the average distance d/2, but that is not the projected area of loading at the base.
RE: Spread Footing - Punching Shear
The punching shear perimeter spreads out from the column at a 45 degree angle. We take the perimeter at d/2 because that's the mid-point and the the best way to calculate capacity.
However, if you project the 45 degree failure down to the soil, it intersects at a distance d from the face of support. right? And, only the load outside this perimeter would contribute to punching. It think that is a theoretically valid assumption. It is somewhat less conservative. So, perhaps that is why the examples don't do it that way. But, it seems valid to me.
It seems logical to me, and if you look at the assumed failure mode the statics should work out to taking a full 'd' on each side. Normally probably doesn't matter too much but if you have a d of 36" then that extra 18" on each side saves a lot of demand. I can't find any examples that do it this way though.. so I guess I'll stick with the more conservative method.
