CAN I CREATE A SOLID, SHELL IT & TURN IT INTO A 3 PIECE FLAT PATTERN?....?.OR DO IT ANOTHER WAY?
Hi there.......thanks in advance for any help. I have searched the tutorials and 'help' but have had no luck in finding an answer. I'm using SW version 2006.
I want to create a 3 piece flat pattern for the part I've attached. I'm not familiar with everything SW is capable of but I have had success in the past with other flat patterns.
I looked into the 'split' command...wasn't successful. Then I thought I might be able to start with the middle section (including the flat section on the top) as a sheet metal part and then create the side parts on assembly....but a 3D sketch on isn't available when creating on assembly.
Our company is presently getting by with a hand laid out pattern ....but there is a lot of trimming and filling going on.
Any help would be greatly appreciated.
RE: CAN I CREATE A SOLID, SHELL IT & TURN IT INTO A 3 PIECE FLAT PATTERN?....?.OR DO IT ANOTHER WAY?
What happened to the dimensions?
Second thing I noticed is that Sketch1 is not placed with obvious symmetry about the origin.
Third thing I noticed is a fillet in Sketch1 that appears at one "bend" but not on the "symmetrical" geometry.
One technique would be to add the missing fillets for the bends.
Delete the faces rather than Shell.
Thicken the resulting surface bodies into the individual sheets.
The sketch wasn't defined because I had imported it from AutoCAD to give the idea of what I was trying to do.
I did delete the faces(leaving the side piece)but the problem was I couldn't turn it into a sheet metal part or flatten it. I really need the flat pattern but I just don't know how to get there.
Any other suggestions?
When I was able to do that at all, an otherwise identical part that started out as sheet metal performed more logically in its interactions with other parts, and SW crashed less.
I.e., I infer that there is some internal conversion mechanism from solid to sheet metal, but the parts are somewhere somehow fundamentally different.
... as are real castings and real sheet metal parts, so I don't see the difference within SW as a huge problem.
Mike Halloran
Pembroke Pines, FL, USA
I routinely model blocks, hollow them out, and convert them to sheet metal.
Don't let SolidWorks do the ripping. Do it yourself.
JHG
I need a bit more of a step by step explanation if that's possible.
Thanks in advance.
First thing I did is "fix" the sketch as it appeared no real effort on getting it constrained. (I didn't change the dimensions.)
Then I offset the faces by zero.
Thickened them and converted to sheet metal.
In fact it takes no more time or difficulty to sketch correctly.
(I'm not sure if r2006 would allow multi-body sheet metal.)
If not, it is a simple process of doing one at a time.
I do ripping as sketches and extruded cuts. Do you understand how your sheet metal part will be flattened out? Typically, I want this done my way.
Use the linked dimensions feature. Sheet metal creates the link "Thickness" to control all the wall thicknesses.
JHG
Unfortunately SW 2006 does not have the Convert-Solid capability. In version 2006 the way to convert to sheet metal is to rip and then insert bends.....this has worked for me on more regular shaped parts and gives a one piece pattern. If there is another way to slit the part into 3 parts, convert to sheet metal and unfold it, I haven't found it.
I think I might be SOL on this one.
I often have to use this legacy tool rather than Convert-to-sheetmetal.
