NX 9.01 Shop Doc Template Modification Problem.
I've been trying to follow a guide to make small changes to the shop docs.
Link
At the part where in Excel, you Publish the .Xlsx into a new .htm is the problem.
Even without altering the .xlsx just open in Excel, and republish the .htm makes NX throw a bunch of .tcl errors trying to use the new template.
I've tried using Excel '13, and .07.
Comparing the 2 .htm files "the OOTB, and the fresh republish"
I do see differences. Some Paragraphs added, some removed, some numbers slightly different.
I'm assuming this is either an Excel version issue, or the way i'm publishing?
Has anyone succeeded in publishing a shop doc template in 9.0?
Heres the Error, and the Published .htm .
Link
RE: NX 9.01 Shop Doc Template Modification Problem.
If you don't hear back, then please log a call with GTAC.
Mark Rief
Product Manager
Siemens PLM
Let us know if that works.
First I set them all to general, then for aesthetics slowly put some back to numbers to not get 15 zero's after the decimal.
In the end its fixed, and all the ones that matter are back to numbers with few decimals. Not sure which one was the culprit.
It gives syntax error for tool name (in your case "UGTI0202-029").
The tcl proc DOC_format_var_with_style can only handle integers, floating points & scientific notation. It applies the format specified for a particular cell. Because it uses mso-number-format, which is an excel cell style for numbers, it can't handle the string being passed. It assumes the string is a variable name which is why it throws the error.
From what I have looked at, you can't error proof this because the CSS information is stored directly into the Excel template which is not handled by the tcl files. Its kind of like trying to stuff a square peg into a round hole.
