Guardrail Loads in 2009 IRC
I would swear it is in there. Does anyone know where the design load is specified for a Guardrail in the 2009 IBC? R312 doesn't specify a load. I believe it is 200# regardless of post spacing, which is less stringent than the IBC requirement.
RE: Guardrail Loads in 2009 IRC
That is the IBC reference. I need the IRC reference.
http://www.awc.org/Publications/DCA/DCA6/DCA6-09.p...
See pages 15 & 16.
I found it noteworthy that they had modified their joist spans for Southern Yellow Pine, presumably because the design values for that species was downgraded recently.
“Faith is taking the first step even when you don’t see the whole staircase.” MLK
