Way to thermally brake a steel-to-steel connection?
I have a simple diagonal brace on the exterior of a building starting 6' out from the sidewall and bracing the building perpendicular with the ridge. I have insulated panels on the exterior of this building (8' o.c. steel columns) and my diagonal is tying into the steel columns via a bolted shear-tap type connection that is penetrating through the insulated panels. Is there a way to thermally break that bolted connection such that I don't get condensation on the inside of this steel column? It is in a livestock containment building and therefore will have plenty of humidity to condensate on that cold surface.
Thanks.
Thanks.
RE: Way to thermally brake a steel-to-steel connection?
Dik
