Adding part property to ID symbol
When we put ID symbols on an assembly drawing we have a split circle with the detail number on the top & the sheet number of the detail on the bottom. Is there a way to use an attribute from the part property that your attached to for filling in the sheet number. I have an attribute called SHEET_NO in each of the parts that would contain the sheet number. I have the text set for the lower text in the ID symbol dialog set for <W$=SHEET_NO> but when I do an update on the parts list the lower circle text stays blank. Thanks.
John
John
RE: Adding part property to ID symbol
www.nxjournaling.com
