Section Lines are not visible in Break View
Hello
I am using NX 8.5
When I add section view to already existing Break View it gives me message as follows.
"The View Break will result in a hidden section lines" When press OK on message section line is not visible.
So my question; Is this message is a warning or a Bug?
Please see the attachments.
I am using NX 8.5
RE: Section Lines are not visible in Break View
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks!
So do you mean that there will be fix for this in coming future or next version of NX?
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
If you look in the part navigator the section lines are being placed on layer 257!
In NX this layer does not exist, if you select them use the move command and place them on the correct layer you good to.
As for the section letters you need to either suppress the view break and copy them and then unsuppress from part navigator.
This information should add your drafting code writer's to correct issue easily.
Glen Surratt
Senior Designer
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Your right, and if you close and reopen saved part section will migrate right back to layer 257. {So not data bankable as stable part!}
I needed a work around to keep moving just like some other users.
There been 4 PR's opened turned to ER's since April and this not fixed yet.
This August no path yet!
Respectfully Glen
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Respectfully Glen
