150-psig Steam Turbine and Maximum Pump Discharge
I'm looking at a set of PID's for a turbine driven pump.
The Client has no record files for either pump or turbine.
Using 150-psig steam and exhaust to atmosphere, is it reasonable to estimate 150-psig maximum possible pump discharge pressure?
RE: 150-psig Steam Turbine and Maximum Pump Discharge
Just what is it you're trying to do?
Please give all the info you have, we won't bite......hard.
Sounds like someone needs to go and read the name plate or look at the discharge pressure to me.
