Electronic Data Transfer Agreement
Recently I have been asked to sign an Electronic Data Transfer Agreement in order to receive CAD drawings from an architect. This is the second time I have been asked to sign such an agreement. In short, the agreement says that the drawings are for reference only an the architect has no responsibility if the information contained with the drawings is correct. Huh????? how am I suppose to design a building if your drawings are for reference only.
What do others do in this instance? Seems like I am forced to sign their agreement or not get any help from their CAD files.
RE: Electronic Data Transfer Agreement
Perhaps it indicates that the architect looks at you as just another contractor rather than a fellow professional. Ugh.
Maybe you need to have a talk with their top brass.
Maine EIT, Civil/Structural.
This is simply because the final drawing gets checked. The engineer or architect or other responsible profession is only checking the actual physical drawing, not the electronic CAD file. Even a drafting check isn't going to check all the possible things that could be subtly drafted wrong.
If something's called up as a W310 but scaled in a detail somewhere as a W250 I want something to point at if someone decides to blindly grab that detail out of a CAD drawing and use it as the basis for their HVAC detailing. I also don't want people measuring my conceptual connection details and things like that.
It's probably different if you're doing stuff with BIM or combined models where the model is the real deliverable.
My point is, if I can't find it on your drawings how am I suppose to detail the structure properly on my drawings which everyone is going to use to build off of.... and how is the contractor suppose to build this in the field. So in the end I suppose to sign this paper relieving the architect from the responsibility of giving up incorrect drawings? That just doesn't make any sense to me.
The architects's agreement is, er, architected, for the 'old' situation, where the signed and sealed paper print governs, whereas, in theory, with BIM, the model governs.
Perhaps your lawyer needs to be talking to the architect's lawyer.
Mike Halloran
Pembroke Pines, FL, USA
I would guess that the architect simply doesn't know how to do the BIM data correctly.
TTFN
I'm not concerned about repeat work with the owner as I am beginning to see how hard they are to work with.
I don't envy your situation, as you're basically out of time and needed to put everyone on notice weeks ago...
I guess I am just a whiner. I am now being told that if I don't sign the agreement and our drawings don't match the arch drawings that I will be at fault.
I see the same thing. I had a guy from my own company ask 'why I need a full set of drawings, you have what is related to the bridge, so who cares"
Turns out the grading plan, profile drawings, etc are important. Who knew, certainly not the sales guy.
If someone wants to use my details, GREAT! that means its a good detail!
Oh, and if the Architect does not think that you are part of the team, but the owner does, just communicate with the owner. Things will change one way or the other.
Mike McCann
MMC Engineering
Hell, if you're seperately contracted, get the owner to intervene as the intermediary in distributing these documents. They should be able to demand some kind of proper non-bullshit issuance for design. They need to issue some frozen baseline for design, be it a model or drawings.
Dik
TTFN
Dik
How did we even end up down that road where we all work for the architect?
If the CAD technician working for the architect understood what is necessary for the building layout, AND if the architect also understood that his/her CAD technician needed time and direction to produce a workable drawing, all would be good and the paper drawings could be held as the standard.
Since the proliferation of CAD, I have maintained that there should be one additional test before any design professional is granted a license: Take your PAPER drawing and a tape measure into the field and lay out the work WITHOUT referring back to your CAD model. If the paper drawing provides adequate information and you can indeed do the layout, then you pass the test.
I recently had a provide where the architect provided an angle from a main (orthogonal) grid line to locate a skewed grid line. No where in the drawings was there any hint as to where the skewed line might intersect the other grid line. Yet in order to obtain the contact drawings in CAD format, a similar agreement had to be signed AND the specifications were clear that ONLY the paper drawings were to be considered correct. The example I cite is just one out of dozens of layout conundrums that the project presented. And I was only working on the foundation to produce layout drawings for the concrete contractor. Somehow it got built, but I'm sure at great cost to many of the subs on the job.
Ralph
Structures Consulting
Northeast USA
1. You need Arch drawings to do work. It is not common to sign releases between team members on the design side; however, since your contract is with the owner, I can kind of see why the Arch is requiring this - because they dont have a contract with you. In my humble opinion, I wouldn't read into the release too much. It's CYA for the Arch who sounds like they are not up to speed with the rest of the team. They should actually be ahead of everyone else and coordinating all efforts, that's their job.
2. If you have a contract with the owner, that is who you should be communicating with. All requests for information should go through them since they are your client. It is therefore their responsibility to get you what you need when you need it, which leads to #3.
3. You need to be clear from the beginning what you need and when you need it. This is a VERY common challenge in our industry. Architects who only gives pieces of the drawing set and don't give a full set or important sheets (ie sections) until the week of the due date. This is something you have to watch for and protect yourself against. If you don't draw a boundary of what you expect with your client (see #2), then delay in getting information will eat you alive. And it's kind of your fault for not being more clear and firm in the first place.
4. It is also critical to, somehow, quantify how many design changes/iterations are in your fee. Again, this is pre-planning stuff and you should be watching for this and playing defense to protect yourself. Any good consultant worth their weight on a team is understanding of design developments and even significant changes during the design phase. But it very much depends on the level of communication within the team, the leadership of the Architect and your relationship with the Architect/Owner. Good relationships respect your time and communicate well. Bad relationships don't. Sounds like you are in the latter category from the one-sided picture you have shared. Either way, what you will put up with depends on your fee (which hopefully has room for this type of thing), your relationships, how you are treated and the level of hard work you are willing to put forth in order to be seen as a responsive team member for consideration on future projects. We get last minute changes all the time and handle them differently depending on the client.
Sounds like your deadline was last week, but hopefully this gives a little insight into the multitude of complex factors I feel are at play here.
