Edit object display and translucency
I am working in NX8.0.3.4
Why is it that when I edit object display to change a face color it asks if I want to turn on translucency? I always have to click NO. But there is a "yes always" button. If I mess up and hit the yes always, because I happen to get click happy, then I am stuck with turning off (Preferences - Visualization - translucency) in the pull down. What a pain! Is there a easier way to switch this, and why can't I have a "NO always, leave me alone" button.
RE: Edit object display and translucency
Preferences -> Visualization Performance -> General Grpahics
...and you've either changed the translucency setting while the 'Edit Object Display' dialog was open or the body/face had already been previously edited and had the translucency set to something other than '0' when you opened the dialog. If translucency has never been messed with for the object selected and you're ONLY editing it's color, the system should NOT have asked you to 'Enable Translucency'.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Note that if anyone else wants to use this utility, that's fine, just keep in mind that it's specific to the version of NX that you're running. So if you want this to work with say NX 8.5, you'll need to edit the .bat file and change the two places where you will see '\NX\8.0\' to '\NX\8.5\'. Now you can use this with any recent version of NX just as long as you make the correct changes keeping in mind that it will always require digit(s) before and the first digit after the decimal place of the NX version, such as \7.5\ or \8.0\ or \8.5\ or \9.0\. Do NOT include anything more than just the first set of characters. In other words, the MR's done count, just the primary version designation.
Anyway, give it shot and let me know if this helps.
BTW, I'm still going to work on getting something that can be reset from within NX itself but this will work for now.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
