DCS/PLC CPU models
DCS/PLC CPU models
DCS/PLC CPU models
I don't suppose anybody could tell me what model of processors are used in common industrial PLC/DCS controllers? I assume the majority are Intel based possibly Xeon for higher end controllers. I heard some old Siemens S7 CPU's use Mitsubishi chips.
I'm more concerned about DCS controllers since they handle a lot more network data. I just want to do a small study on industrial controller performance.
Dan
RE: DCS/PLC CPU models
I think what your asking is controller connection limit. Thats all in detailed user manual PDFs provided by the manufacturer of the dcs/plc or pac controller.
I'm not asking for facts and figures and yes I have the controller spec sheets I'm talking about microprocessor models.
Dan
I don't expect they use typical LGA socket type processors found in personal computers no but I know for certain they don't produce their own chips except maybe Honeywell but still I doubt. I suspect at least some of the processors are of the Pentium/Xeon x86/64 family. Smaller PLC CPU's possibly not, I would guess at Texas Instruments/Motorola RISC type models.
I have been told that the SLC 5 series uses an Intel 186 processor to handle communications, math and timer operations. Boolean logic is solved with a custom chip.
The biggest issue you have with the type of processor is the endian format of the data.
Allen Bradley = intel = little endian format
Siemens = motorala? = big endian format
Not sure what the other manufacturers use?
http://en.wikipedia.org/wiki/Endianness
If your integrating the two processor above you need to be aware of it.
I have been told the same as 'djs' about the SLC 5 series.
But I have never heard that Siemens use a Motorola processor.
Kind regards
Honeywell's HC900 (a modular I/O rack PAC, process automation controller, not a PLC) CPU module uses the e300 32 Bit RISC based PowerPC Architecture, according to its spec sheet.
