Reciprocating Compressor: Capacity
I am a bit confused with terms that define the capacity of a reciprocating compressor. While mostly the compressors are specified in terms of FAD (standard or actual), some manufactures specify compressor capacity at a certain pressure. Is the pressure referred above the maximum discharge pressure?
I have a compressor whose capacity rating is 18 CFM at 12 Ksc. (Receiver volume: Around 250 lit). My process application requires 15-20 CFM at 5 Ksc. Application: Continuous for 4 hrs. per day
I would like to know whether my compressor is sufficient to meet my above process needs.
Also does the compressor discharge flow rate vary with the pressure employed during the application ?
Is there any means to measure the air consumption rate (without flow meters)?
Thanks in advance for the replies..
RE: Reciprocating Compressor: Capacity
Also does the compressor discharge flow rate vary with the pressure employed during the application ? - No
Is there any means to measure the air consumption rate (without flow meters)? - You can do it from receiver filling time, approximately
