Riser Guard welded to Conductor/ pile
As per subject, can we weld riser guard to conductor/pile? If it can be welded to conductor/ pile, is there any example/ platform which adopt this?
*Platform is fixed structure type and it is supported by conductor which also act as piles.
RE: Riser Guard welded to Conductor/ pile
I hate Windowz 8!!!!
The weld class from a fatigue standpoint is likely to be very poor and you run a risk of any crack which initiates in the weld migrating to the main body of the conductor pipe with catastrophic consequences.
It would probably be safer to have a riser guard clamped onto the conductor rather than welded. This will also be easier and quicker to install than a welded solution.
