SE V18 .tmp file problem
Using SE V18.
When modeling assemblies if trying to save, a "file could not be found" window will pop up and the file to be saved will disappear in the directory. In it's place will be a .tmp file. If I rename the .tmp file to the correct file name and extension I can work on the file again.
This is on an older dell XP laptop that is not networked. Looking for some assistance as to why this is happening.
RE: SE V18 .tmp file problem
Hmm, I used to have similar happen when the network crashed while I had the file open - however, since you don't have the network issue that's probably not it.
Could it be something else to do with the hard drive you are working from, perhaps a background task interrupting things?
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
As Kenat suggests "a background task interrupting things". Look at your anti-virus settings. Your AV may be incorrectly flagging and removing/quarantining the SE files.
http://about.me/davidmerritt
I have also thought it has to do with the AV settings, but I have not been able to figure out how to tell McAfee how to bypass SE files.
I was just wondering if anybody else ever saw this when not on a network.
