Catia V5R19 Dimension tolerance text size
I can't seem to find where or how to change the tolerance text size.
I was able to change the dimension size no problem, but would like the tolerance to be equal size to the related dimension.
Is this something I can set in the options so every dim would come out the same, or do I have to change all individually?
Thank you, hope you can help me out.
TM
RE: Catia V5R19 Dimension tolerance text size
try using tolerance style/type/description INC_NUM2, this one gives me same size tolerance as the dimension.
dimension look and feel are usually defined in standard...
Eric N.
