Autodesk Simulation Mechanical/Multiphysics
Hi
I am working on an IGS imported assembly of a file. How do I simulate screw connections on the IGS assembly? I tried using bolt function but something doesnt seem to work.
Harsh.
RE: Autodesk Simulation Mechanical/Multiphysics
With iges an assembly is converted into a single part. You need more than one part to create a bolted connection.
You could opt for a step file or split the iges up into separate parts.
