point mobility and sheet metal automotive parts
how to go for designing parts like seat mountings ,rear panel floor,center panel floor so as to make them NVH compatible ? what considerations should be taken that so that point mobility of structure will be less ?? what factors should be kept in mind while designing the parts to make it NVH friendly ??
RE: point mobility and sheet metal automotive parts
nyone for this question ..thanks in advance ?
What I infer from outside the industry:
I think seat anchors have to be designed for pullout resistance and fatigue resistance, but in terms of NVH and human factors, it's only important that the seats don't wiggle or squeak.
Floor pans are designed to be thin and hence cheap, and are corrugated and coated with damping material to minimize transmission of road noise and radiation of structural noise. Nobody cares how stiff they are, except that customers might perceive a noticeably flexible floor as flimsy. Actually, for unit bodies, the stress guys might like to see a little shear stiffness in floor pans, but that's not directly a NVH issue, except to the extent that everything affects everything else
I think Greg was trying to say that NVH is important in most/all automotive systems, to such an extent that it's impossible to condense it all into a handy checklist, or a few paragraphs, or a lot of paragraphs, or even just one book. You might want to invest in a few; start looking at sae.org .
Mike Halloran
Pembroke Pines, FL, USA
