Radiography for Shell and Tube heat exchangers using ASME VIII
Dear all,
I would like to know how to distinguish when a heat exchanger is designed by using a spot, full or 100% radiography. Depending on which kind of test method used a different E joint coeficient is chosen.
Once I have had a look to standards I think that you can choose the method that you prefer, and that will change some parameters (thickness...)
Thanks so much,
Thanks so much,
RE: Radiography for Shell and Tube heat exchangers using ASME VIII
Mike
