Trying to save Drawings to .CGM via command line
Hello everyone,
I've been trying to get this to work and my final attempt says "No license is available for this batch Utility" so I think I am on the right track.
Basically what I am trying to do is run a batch utility from command line to save my drawing as a CGM.
What I did was I CD in the bin directory where the CATDMUUtility.exe is located and tried this line below.
CATDMUUtility2D -h CATDMUUtility2D -id c:\DassaultBinLocation\FileName.catdrawing -cgm c:\TEMP\TEST.cgm (obviously this isn't where I have my CATIA installed)
Since I am having a license issue and I cant get the right one until later I was curious if anyone else had gotten this to work and if my syntax looks correct.
Thanks everyone.
Slaen
Thanks everyone.
Slaen
RE: Trying to save Drawings to .CGM via command line
