Pressure temperature rating of Flanges as per UG-44 of ASME Sec VIII Div.1
The pressure temperature rating of Flanges as per UG-44 is in accordance with the appropriate standard e.g. B16.5, what shall be the pressure-temperature rating for MAWP calculation purpose for SA 266 grade flanges which P-T rating is not mentioned in B16.5?
RE: Pressure temperature rating of Flanges as per UG-44 of ASME Sec VIII Div.1
Mike
