Thermal stress analysis - CFBC boilers
Have anyone done stress anslysis of wingwalls of CFBC boilers?
What are the boundary conditions to be taken?
Could you pls explain for academic purpose.
The case is like this. I have 2 L shaped tubes, which are connected together by means of a plate (in vertical portion of L)
The tube pierces a wall at both ends, which are moving down.
At the piercing location, refractory material is put.
Tube carries 400 deg C steam.
How do i apply boundary conditions?
Is there a simple theoretical way to approx this situation. to a L shaped gemoetry fixed at both ends and having thermal expansion?
