STAAD Beam End Forces
Good Day All,
I am a Naval Architect working in the Offshore Oil and Gas industry.
I am very pleased to have joined your forum that I have always found very useful during my career.
I wish one of you could clarify my doubt:
I need to design the bolted connections in a steel structure composed by a top frame installed on vertical pillars. When I verify the connection between the pillars and the existing structure on which the new structure will be installed, I can use the reactions in the support points to design the connection. But when I have to verify the connection between beams, as there is no support I should use the beam end forces.
The problem is that I have almost a hundred of connections that I need to verify with 4-5 beams intersecting in each node.
Referring to the figures attached, if I have to design the connection in the node 6, which forces shall I take into account? Is it correct taking into account only the beam end forces of beam number 5 or should I consider in some way the contribution of all the beams in a node?
Many thanks.
Many thanks.
RE: STAAD Beam End Forces
Now the attached have been correctly uploaded.
Ram Connection can be used in conjunction with STAAD.pro to help, assuming this is based on US or British standards.
Actually we have just started to use RAM Connection in our company but we need to get used to it. For the brace, I would assume that you meant the maximum beam end force between beams 36, 41 and 103, is that correct?
