1920 Detroit Electric Car Battery fuse question
I am working on restoring a 1920 Detroit Electric Car. There were no fuses in the battery circuits and I want to install fuses.
The car has two battery packs, one in the front and one on the back, each battery pack is 42 volts DC with 240 amp/hour capacity.
From what I have been able to find out, the max amp draw may be 60 amps at starting when the front and back batteries are connected in parallel. I assume that once the car starts rolling the amps will drop.
I do not think I need to be concerned with time over current as much as having an instantaneous clearing of a short circuit.
Any thoughts and ideas would be appropriated since I am not familiar with the level of fault currents that can be produced by batteries.
RE: 1920 Detroit Electric Car Battery fuse question
Carry a couple of bigger fuses.
Mike Halloran
Pembroke Pines, FL, USA
'output' fuse you'd still be screwed.
Keith Cress
Thanks for the reply. The DC system is not grounded. I think I need to fuse the + and -.
I will investigate the HRC fuse.
