Applying a moment in NX and getting incompatible mesh error
thread727-212840: Applying a moment
Just so everyone knows, in reference to the above thread, if you are using NX 8.5 and are trying to apply a moment to a structure and are getting the error "incompatible mesh", it is because you are using "Linear Statics with Global Constraints" instead of "NONLINEAR statics with Gobal constraints". This can be found in the solution box in the dropdown menu under "NX NASTRAN". Good luck, hope this helps atleast one person because I wasted a ton of time trying to figure out what was going wrong.
