is your n2 consumption high?
I have a few customers who are N2 cutting w a laser assist ha ha I mean N2 assisted laser cutting. They go through a lot of N2. If you are finding high N2 consumption and/or have to turn the N2 pressure up higher than normal, here's a simple test- take a nozzle, seal the opening up, then put it in the head and turn the assist gas on. If you hear N2 blowing out, you have a leak between your N2 proportional valve and the nozzle. It sounds simple but an alarming number of machines I test have a leak. Testing the O2 is also good idea, O2 leaks like to burn up machines.
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
RE: is your n2 consumption high?
When testing with a plugged up nozzle, I would add to make sure you don't test at max gas pressure. The lens will probably not crack, but you never know.
"I am stuck on Band-Aid brand, 'cause they are stuck on me"
