pipe rating question
Hello everyone!
Can someone explain me what is intended with "rating" of a pipe as per ANSI b16.34?
I understand that for growing pressures and temperatures the pipe should be more resistant..but I really don't understand the true meaning of rating.
Thank you in advance for answering me!
RE: pipe rating question
The ANSI pressure rating system is very common: http://www.engineeringtoolbox.com/ansi-flanges-pre...
JA boomer has it right, but can you be a bit more precise as to the section or wording you're having difficulty with.
