What is happening here?
This is a one month old sewage screening device. It is in an enclosed rated area and it's not pleasant, but not as nasty as most headworks. I have used 304 with 316 fasteners for years for this application for years and never saw anything like this. There was no welding done during or after erection.
Steve
Steve
RE: What is happening here?
Thanks guys !!!!
This looks like stray iron contamination.
B.E.
You are judged not by what you know, but by what you can do.
Steve
#3 looks like weld splatter from nearby steel welding
#4 looks like someone used a brush or wheel that had been used on steel.
and so on
What concerns me are the bolts. Will they remove the bolts, clean, and then install new hardware (that has been passivated)?
If they pickle with bolts in place they will only get acid into the joints, and they may cause serious corrosion damage.
This could be true of all mechanical joints. Getting them clean in one thing, properly rinsed can be another issue.
Plymouth Tube
