Model edge lines on (deformed) contour plot
Hallo all
Does any one perhaps know how to show the edge lines of a 3D model on a stress contour plot? (also in case of a deformed model/geometry).
I am only aware of the Filled Edges setting; but, it plots lines representative of all element edges (not only for edges lying on the model outer boundary, i.e. it shows the complete mesh). Many times one prefers a cleaner plot, or, sometimes a lot of fine mesh details could even block out the contour details.
Thank you
Gert
Thank you
Gert
RE: Model edge lines on (deformed) contour plot
The true answer to your question deals with the complex notion of feature detection.
A simpler and direct (though weaker) method, accessible in FEMAP is to use free edges:
- activate free edges (View Select > Free edges)
- in View Options > Tools and view style > Free edge and Face > Free edge / Backface > select "2 View, Draw Model"
- Turn off element edges
This will show free edges and your model. This should be compatible with contour plotting.
This is however a "weak" method, because free edges aren't feature edges (I'm guessing you are thinking of feature edges when saying "the edge lines of a 3D model"). For example if two wedge elements come together to form a corner, the common edge isn't free and won't show up. For tetra mesh free edges will typically appear as a "dotted" line.
Macros exist if the simple method isn't satisfying for you.
You know your story..! - thanks a lot! This little bit of functionality already evaded me right from the beginning when we started using Femap. I tested the method as proposed and could see why you call it "weak", but it gives me 80% of what I need - enough to live with I guess..
Best regards
Gert
