Sum of forces display acting on a body
Dear Adams professionals,
I can't figure out how to measure, and display the acting forces (torques) on a body. For example I made a cube with mass, and set the default gravity with default orientation. When I simulate the cube falls "down". How can I measure the acting force on the cube?
The methods I have tried:
-CM right click, measure; Set the appropriate "Sum of forces on body" measure. RESULT: nothing measured.
-Measuring with function FM(). RESULT: nothing.
Any ideas?!
Any ideas?!
RE: Sum of forces display acting on a body
Cheers
Greg Locock
Thank You for the reply! I will try the MSC's forum then. If I have any solution I will post it here too.
