Operation Start for Tapping in NX Post
thread561-177672: Post Builder - Tap Cycle
I have the same issue as in the referenced thread and it seems the original question was never fully answered. In our case I would like to have a different operation start and op end for tapping(if possible)- I like to use G95 so the the operator is looking at the thread pitch rather than a random feed number based on the spindle speed.
RE: Operation Start for Tapping in NX Post
proc PB_CMD_tap_start { } {
# this command used with PCB_CMD_tap_start and PCB_CMD_tap_start
# will output an M and s code before tapping cycles
# put this command in the above the cycle ouput blocks
# in "tap" event
global mom_spindle_speed tap_set
if { $tap_set == "OFF" } {
MOM_output_literal "G95 (FPR)"
MOM_output_literal "M135 S[format %0.0f $mom_spindle_speed]"
set tap_set "ON"
Greg
I'm sure that's close - but I'm still learning post builder and still very green with Tcl. I have the command above the G84 output(in the same block) but I still get the error in the attached screenshot. I've tried to figure it out but I'm not having much success. Could you possibly have a look? Help is much appreciated.
NX9.01
There is a section on UDE creation
There is a lot of information available from the PLM World website from previous user group presentations that cover creating and modifying posts. www.plmworld.org membership is free to current customers of NX.
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6, NX7.5,NX8.5, NX9.0
Vericut7.3
proc PB_CMD_tap_initialise { } {
# this command used with PCB_CMD_tap_start and PCB_CMD_tap_end
# put this command in the "start of program" event
# Also this will initialise the coolant dwell
global tap_set
set tap_set "OFF"
and this bit
proc PB_CMD_tap_end { } {
# this command used with PCB_CMD_tap_initialise and PCB_CMD_tap_start
# put this command in the "cycle off" event
if { $tap_set == "ON" } {
MOM_output_literal "G94 (FPM)"
set tap_set "OFF"
Greg
