Glass Sphere/Ball Cracking Simulation
can anybody help me with following situation.
Please watch this 5sec simulation.
https://www.youtube.com/watch?v=G3H9UJlTvfk
Im trying to get the same in ABAQUS 6.12. I already finished everything for preprocessing.
What Im gettings is
I tried all type of load with minimum and maximum values. For low magnitude of stress, the calculation doesnt finish.
I might have wrong Material Paremeters: My Material Parameters are as following:
*Brittle cracking, type=displacement
Tensile strength (Say 5 MPa), 0.0
Post-peak tensile strength (say 5 Pa), post-peak crack opening displacement
(say, 1e-6 m)
Post-peak tensile strength (say 0.1 Pa), ultimate post-peak displacement (say,
1e-5 m)
*Brittle shear, type=retention factor
1., 0.
0.5, 1e-6
0.01, 1e-5
*Brittle failure, cracks=1
1.e-5
THANKS A LOT!
What Im gettings is
.I tried all type of load with minimum and maximum values. For low magnitude of stress, the calculation doesnt finish.
(say, 1e-6 m)
1e-5 m)
1., 0.
0.5, 1e-6
0.01, 1e-5
1.e-5
THANKS A LOT!
RE: Glass Sphere/Ball Cracking Simulation
Here is the link:
http://files.engineering.com/getfile.aspx?folder=8...
