Journal for X, Y, Z format
3
RE: Journal for X, Y, Z format
Are you asking for the ability to create X,Y,Z expressions of a selected point?
If so, that capability was added in XN 9.0 as the new 'Measure Point' function. Note that the expressions created, either a single 'Point' expression or individual X, Y and Z expressions, are associated with the 'Measure Point' feature which will update if the model is modified and the referenced 'Point' is moved as a result.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
You want the coordinates all on one line?
Other than that, I don't see the difference between your example output and what the information window gives you...
www.nxjournaling.com
yes Cowski, all in one line would make it easier to copy and paste to another sheet.
John L.
NX Support
Win 7 64bit NX 7.5.4.4 TC 8.3.1.1
Attached is a GRIP program that will do what you want. You select the points (as many as you wish) and it will write the data, in the format that you're looking for, to a text file.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Below is a journal that will allow you to select points and write the information directly to the clipboard.
CODE
'April 3, 2014
'select points on screen, copy information to clipboard
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports System.Windows.Forms
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim theUfSession As UFSession = UFSession.GetUFSession
        If IsNothing(theSession.Parts.Work) Then
            'active part required
            Return
        End If
        Dim workPart As Part = theSession.Parts.Work
        Dim pointValues As New List(Of String)
        Dim response1 As Integer = Nothing
        Dim mode1() As Integer = {0, 0}
        Dim pointDisplayMode As Integer = 0
        Dim objectpoint(2) As Double
        Do
            theUfSession.Ui.LockUgAccess(NXOpen.UF.UFConstants.UF_UI_FROM_CUSTOM)
            response1 = theUfSession.Ui.PointSubfunction("Select Point", mode1, pointDisplayMode, objectpoint)
            theUfSession.Ui.UnlockUgAccess(NXOpen.UF.UFConstants.UF_UI_FROM_CUSTOM)
            If response1 = 5 Then
                Dim myPtVal As String = "X = " & objectpoint(0).ToString & " Y = " & objectpoint(1).ToString & " Z = " & objectpoint(2).ToString
                If pointValues.Contains(myPtVal) Then
                    Exit Do
                Else
                    pointValues.Add(myPtVal)
                End If
            End If
        Loop Until response1 <> 5
        Dim myStringBuilder As New Text.StringBuilder
        For Each pt As String In pointValues
            myStringBuilder.Append(pt)
            myStringBuilder.AppendLine()
        Next
        Clipboard.SetText(myStringBuilder.ToString)
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image when the NX session terminates
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
        '----Other unload options-------
        'Unloads the image immediately after execution within NX
        'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
        'Unloads the image explicitly, via an unload dialog
        'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Explicitly
    End Function
End Module
Thanks John...although I was unable to compile the grs (64bit) - saying we don't have license, but I know we do.
Thanks Cowski, the journal is great.
John L.
NX Support
I included the executable of the GRIP program. There was no need to recompile it. GRIP is not like other languages in that once you have an executable, it should run on any system.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks Cowski
Journal is very helpful. I've been looking something like this. Is it possible to get point WCS orientation and reduce number of decimal places to 2.
OK, for what it's worth, I've updated my GRIP program so that it now returns the X,Y,Z values set to 2 decimal places. Also, the method I used to get the coordinates of the points are returning the values in terms of the current WCS (GRIP almost always works in WCS space, which can be good or bad, but in this case, it's good). As before, after downloading the file, edit the extension from .zipper to .zip and then extract the files. I've included but the source and executable, and as before, there is NO need to recompile, it should run on any recent version of NX.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Quote (rafl)
Yes it is possible and the changes are pretty easy, which means it is a great time to jump in and get your hands dirty!
To get the desired number of decimal places, you can use a format string in the .ToString method. It will look something like this: [variable].ToString("0.00"). Add the format strings as desired in the following line:
CODE
In thread561-325985: Change Global Co-ordinates to Local Co-ordinates using NXOpen? you will find some code to convert absolute coordinates to local (and vice versa). The functions as written expect a Point3D object as input, which we don't use in the journal above. You will need to either create a Point3D object to pass into the function or change the function so it accepts the array of doubles that we do have (either will work).
Happy coding!
Post back with any specific questions.
