Skip I, O, Q, S, X, Z Rev letters - does it really matter?
I working on implementing a PDM system, and I think we should use straight alpha Revisions, and not skip any letters.
The opposing side wants to follow the ASME guidelines and skip I, O, Q, S, X and Z. I would be more satisfied with this if someone gave me some good arguments on why this is so important. With or without a PDM system skipping letters introduces additional complexity, and it is often not consistently maintained around the organization.
The way I see it - there is little opportunity for confusion if we do not skip letters. So what if a machine shop thinks it is revision "1" (ignoring the G and H showing on rev table) if they use the right drawing? (One little idea - for drawing rev letters we could use a font that makes it more clear that an I is not a 1.) Our prototype numbers are 01, 02... two digit numeric counter.
Skipping letters correctly becomes an esoteric tribal knowledge sort of thing that will require a group effort to maintain. I say tribal, because even if it is written down people have to remember to go look at the spec, and who wants to do that day-to-day? People often forget some of the these letters.
Going forward Enterprise PDM will make things in the vault have the correct sequence, but there are plenty of other activities. For one thing, our ERP gives no guidance on this issue (and PDM and ERP will not be linked at this stage). Historically we have not even consistently followed the ASME system in engineering. I and O were often skipped, but Q, S, X and Z were often not. I and O are easier to remember (and far more frequently reached). I must admit it bothers me a bit to use I or O. We could compromise and just skip I and O, make that our system... or get rid of the whole, perhaps overblown, convention.
Yes, we can teach people to follow the system more, but is it worth the effort?
Serious Question: For PDM migration - Do we bump legacy documents up a rev letter if they have one of the forbidden letters? Release new rev with an ECO? We probably have several hundred drawings with forbidden revision letters.
Overall I think it is not worth the trouble!
Thanks for any opinions, rants or examples.
RE: Skip I, O, Q, S, X, Z Rev letters - does it really matter?
If you don't want to follow the standard (whichever standard you use) of revision letters, leave off the reference of the standard called out on your drawing format/notes.
You can setup rev letters/numbers anyway you like in PDM.
Chris, CSWA
SolidWorks 13
ctopher's home
SolidWorks Legion
I can be confused with a 1
O can be confused with a 0
Q can be confused with an O or 0
S can be confused with a 5
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies to make the best use of these Forums?
"""""" """"""" And Z could be a 2 I guess.
But if that happens, what is the impact? PO says make it to rev Q, drawing says rev Q, they will then make the correct part even if they think it is rev zero. There are probably other scenarios...
Confusion over the revision could ultimately (even if fairly unlikely) come up in this context if there is a disagreement between you and customer and the revision confusion is a (real or perceived) part of the cause.
Like others say I would take this as an opportunity to more robustly enforce this rule rather than a reason to abandon it.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Just to reinforce everyone else's remarks...
Consider the possibility of hand written documents, or someone transcribing at the keyboard. It happens.
JHG
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
Our favourite machine shop has shut down, and the new guys we are dealing with rely on a letter sized printer. This renders E sized drawings unreadable.
JHG
However, 11*17 is pushing it!
My 21st edition of the Machinery's Handbook recommend 5/32" or 4mm lettering on D sized and E sized drawings. This supports reduced sized printing, and it supports that fact that full sized drawings probably are taped to walls, and have to be read from a distance of six feet, or two metres.
There is no mention of this in my 26th edition.
JHG
We did some research on the font size back when me made the change but I don't remember the details.
I wrote a Dispatch script (a software tool) for Enterprise PDM so it will pop up a message if a user tries to use an invalid letter (this way they will know why the state change was rejected by the PDM).
Thanks for all your feedback!
--Scott
www.wertel.pro
Tunalover
I agree! I have that argument often.
Chris, CSWA
SolidWorks 14
ctopher's home
SolidWorks Legion
