Catia V5 Join and Manifold
Hi All
May yet well be another simple question to some of you
I am currently looking at the join operation within GSD. Can anyone please explain what the Check Manifold tool does exactly? I know you can only use this option when joining curves but im not quite getting the jist of exactly what it's doing. I have come to the conclusion that if ticked and attempting to make a join with curves it doesn't work. As soon as I untick this option I am then able to join the curves no problem
Thanks in advance for any help some of you may be able to give
RE: Catia V5 Join and Manifold
If the curves are overlapping then you get this manifold error.
When joining curves, the check manifold option verifies that the result is both contiguous and has a single path (ie. no more than two coincident endpoints at any vertex, and no intersection between curves other than at endpoints). If the join result is contiguous but has more than one path (ie. 3 curves having an endpoint at a common vertex, or a curve having an endpoint at the midpoint of another curve) then the result has connectivity but is not manifold. If the result is not contiguous then it is not manifold and does not have connectivity, but it still can be a joined element.
