invalid attribute
invalid attribute
invalid attribute
All, we have a custom made attribute in nx7.5/TC8.3.3 called checked out, it is of the type string. Now we're moving to nx8.5/TC8.3.3 and this attrib is preventing us to save files with following error ;
+++ An attempt is made to use inconsistent attribute types for attr and desc for attribute CHECKED_OUT.
Why do we get this error; is it save to change the type of this attribute and what should the type be?
Thank you.
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit
RE: invalid attribute
Perhaps you defined a preserved name. If you check the Best Practice of BMIDE you should always use a Prefix for your Custom Attributes, like AB5_CHECKED_OUT
Menk Slot
