Create a positional link to a DrawingComponent in macro
I cannot create a positional link to a DrawingComponent (2D ditto, lets say a cross), by picking that ditto, to a text, in macro.
I've tried something like this:
Dim oSelection
oSelection = DrawDoc1.Selection
Dim oInputType(0)
Dim oStatus
oInputType(0) = "DrawingComponent"
oStatus = oSelection.SelectElement2(oInputType, "Select a 2D Component", True)
If (oStatus = "Cancel") Then
Exit Sub
End If
Dim Myselection As Selection
Myselection = CATIA.ActiveDocument.Selection
DrawText1.AssociativeElement = Myselection
Does anyone found a solution for this?
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
RE: Create a positional link to a DrawingComponent in macro
I can't do it with a ditto...
but i do it for another geometry...
CODE -->
Sub Positional_Link()
Dim oDocument 'As Document
Set oDocument = CATIA.ActiveDocument
Dim oDrawingDocument 'As DrawingDocument
Set oDrawingDocument = oDocument
Dim oSelection 'As Selection
Set oSelection = oDrawingDocument.Selection
Dim oSheets 'As DrawingSheets
Set oSheets = oDrawingDocument.Sheets
Dim oSheet 'As DrawingSheet
Set oSheet = oSheets.Item(1)
Dim oView  'As DrawingView
Set oView = oSheet.Views.ActiveView
Dim InputObjectType(0)
Dim oStatus
InputObjectType(0) = "DrawingText"
oStatus = oSelection.SelectElement2(InputObjectType, "Select Text", True)
Exit Sub
End If
Set SelectedElement = oSelection.Item(1)
Set Text = SelectedElement.Value
oSelection.Clear
ReDim oInputType(1): oInputType(0) = "Line2D": oInputType(1) = "DrawingComponent"
oStatus = oSelection.SelectElement2(oInputType, "Select a 2D Component Or Line", True)
Exit Sub
End If
Dim oSelection1 'As Selection
Set oSelection1 = oDrawingDocument.Selection
Set Selected = oSelection1.Item(1)
Set Ditto = Selected.Value
Dim o2DComponents 'As DrawingComponents
Set o2DComponents = oView.Components
Dim o2DComponent 'As DrawingComponent
'Set o2DComponent = o2DComponents.Item(Ditto.Name)
Text.AssociativeElement = Ditto ' o2DComponent
End Sub
