Unable to deform
Unable to deform
Dear All,
I have a problem using deformable part.
I'am designing an arrow, cut in a sheetmetal, used to indicate the flow direction on our product.
Most of the time it is screwed on cylindrical face.
In my part they are two solid.
A flat one, for drawing purpose.
And a curved one, made by wrapping contour curved on a cylindrical sheet, a divide face, and a thicken sheet on it.
These two bodies are sharing the "Thickness" expression (self explanatory)
And the curved one, need the user input the wrapping diameter value.
When i'am creating the deformable, i'am selecting all features, select the two expressions. Done.
When i'am trying to deform, I get this :
"Unable to deform as one or more member feature have failed during update".
And info windows show me this :
Information listing created by : a4847
Date : 1/04/2014 09:13:54
Current work part : 00-5125-0181-0000-00/1
Node name : niv-w7-ddsjb25j
Update Warning and Failure Report
Thicken(19) Error: No face selected.
What I dont understand is if i'am changing the same parameters in the model, everything is fine.
Any idea ?
Thank you
Stéphane
Any idea ?
Thank you
Stéphane
"My english is bad ? That's why i'am french."
RE: Unable to deform
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Here is the part file.
I spoke about sheet metal, but the part doesn't use any NX sheet metal feature.
Add it in any asm, try to deform, the problem occur.
http://files.engineering.com/getfile.aspx?folder=2...
Thank you
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I've had a similar problem with NX Sheet Metal model. First, I have modeled a simple NX Sheet Metal part. Then, I have divided this one body into 3 bodies using Extrude/Subtract command. After that, I have defined a deformable part. The deformation worked in actual part. But, if this part was placed into assembly, it didn't work. I received exactly the same error as you are getting.
This procedure worked in NX7.5 (don't remember wich qrm). But it didn't worked in NX8.5 (don't now about NX8). So, the problem was reported to GTAC.
Two days ago, the third maintenance pack for NX8.5.3 was released. And now, it works again. So it was a problem with NX version.
Maybe you have the same problem with NX8. Maybe, your part was perfect in NX7.5, but something has changed with NX8. And therefore, deformable part doesn't work anymore. Well, this is just my guessing, since I don't have NX8 installed.
To better understand, how my model was created, I have attached the test model. It is created in NX8.5.3 mp03. This kind of model didn't work in any other version of NX8.5. I have also attached the image of the part, so that you can at least see the part, if you can not open it.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I did this in NX8.5.3mp03.
Never surrender !
Check this one.
Even if it's more "complex" than my first design, 14 features instead of 9 !
It's working as deformable.
Ha ! Je me marre !
It is working.
Looks if the problem coming from NX8.0.3.4
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
