Flag Pole
Flag Pole
Flag Pole
I have been asked to design a flag pole, 250' tall for a flag pole for a flag 50 feet long. heres the kicker, he wants to use old W shapes to make the pole, and have them cut to be tapered to make this thing. I am at a loss how to design this. Anyone ever done this before?
RE: Flag Pole
That sounds expensive, I hadn't heard of it before now.
Valmont used to make tapered square and rectangular tubes.
Perhaps you could use a rectangular HSS as the core and weld tapered plates to the short sides to give the impression of a wide flange.
Michael.
"Science adjusts its views based on what's observed. Faith is the denial of observation so that belief can be preserved." ~ Tim Minchin
RE: Flag Pole
I can't really visualize how this would work. If it's being assembled out of a bunch of smaller beams, then fabrication may eat up any material savings from using existing material. Also consider coating/galvanizing cost, ease of future maintenance, birdnests, etc. Is there an access tube or ladder? Is the area clear of any airports?
RE: Flag Pole
I have never been asked to do a flag pole design, but we have the possibility of one coming up in the near future so I was just researching last week. Per the attached document Eqn. 5, assuming a polyester flag, 90 mph wind zone and 50'x50' flag, the force from the flag alone is nearing 50 kips. I am not sure if you are going to be able to get forces like that to work with W-sections, or any for that matter. Another issue is torsional resistance, of which will be virtually nothing when using a W section.
RE: Flag Pole
Yea, its all from old W beams from a bridge. Sorta wants to connect them, then cut it to the taper. He then wants to use a piece of old concrete pipe as the base filled with concrete (or he said water), so he can move it around if need be.
RE: Flag Pole
Is this a serious post? If yes first, get a retainer before doing anything. Second, check zoning ordinances if a pole that tall can be built (I wouldn't want it near my house), and aviation restrictions. IMO, this does not sound like something a sane person does unless there are extenuating circumstances that haven't been shared that makes it reasonable (still wouldn't want it near my house). I'm guessing the flag won't be coming down every night.
RE: Flag Pole
I think this an April Fool post.
The definition of a structural engineer: overdesign by a factor of 1.999, instead of the usual 2.
RE: Flag Pole
"I think this an April Fool post."
If this is true, well done!
RE: Flag Pole
I think the flag (and pole) will be coming down every night once you get a small breeze....
RE: Flag Pole
That thought occurred to me as well.
RE: Flag Pole
AELLC you are correct!! got to have a bit of humor in our lives.
RE: Flag Pole
Well played zten, well played.
RE: Flag Pole
LOL
RE: Flag Pole
Had me fooled which is not hard to do nowadays. Since I have an opinion on everthing, I was getting ready to unload on this. Attached is an interesting flagpole case. I was under the opinion that a tapered pole would not develop vortex shedding resonance, just cannot explain how it is occuring in this case , unless the taper is not pronounced enough.
RE: Flag Pole
Well, it's right on par with some presumably-real questions that come up.
Some time back, we got in an inquiry for fabrication of a flagpole, it may have been one of those Wisconsin poles, see the Wikipedia article about that.
Once you get above the height of a powered manlift, you pretty much HAVE to have some type of ladder in or on something like this. At some point, the rope will break, the pulley will snarl or something, and somebody's got to go up that thing and straighten it out. So in the case of the Wisconsin flagpole, I think it said it was 6' diameter at the bottom.
And yes, you COULD build it out of tapered wide-flange beams. Why you'd want to is a different question, as it would be a booger to repaint it or anything, and welding costs would probably offset material savings. See the attached sketch for how I'm visualizing the cross section.
RE: Flag Pole
We are getting more student posts than ever, and the last one I wasted time with, the guy kept debating with me to get the last word in.
Just wait until he gets a job and debates with his boss. He won't last long.
RE: Flag Pole
Great job, ztengguy. Great example of Poe's Law. We get asked to do some crazy things, so I wouldn't be surprised if a client wanted a flagpole like you described.
"Poe's law, named after its author Nathan Poe, is an Internet adage reflecting the idea that without a clear indication of the author's intent, it is difficult or impossible to tell the difference between an expression of sincere extremism and a parody of extremism" -Wikipedia
RE: Flag Pole
steel,
Archis ask us to do crazier things all the time.
RE: Flag Pole
I liked the part about "moving it around". :)
You had me going until then!
RE: Flag Pole
I just did a little sign footing (4x8 sign), and the results always seem like April's fool - Two 4x4 wood posts each with 24" dia x 4'-2" deep footing - that formula for post footings where there is no restraint at the top.
The drawing, to scale, looks out of proportion - comparing wood post to ftg.
RE: Flag Pole
I always seem to get un-intutive numbers when I use the post footing formulas.
