What is the function of lead sheathed on N2XSEKBY cable
What is the function on lead sheathed on N2XSEKBY underground cable other than protection from water and salt ?
Thanks before
Thanks before
Best Regards
RE: What is the function of lead sheathed on N2XSEKBY cable
Excellent oil and chemical resistance
Excellent sulfides resistance
-Electrostatic shielding
In addition, Lead Sheath of Cables can also be engaged to perform the electrical function of sharing the earth fault current with the armour[Fault current carrying capability].
Lead Sheath also protects cables against radial moisture ingress(eliminating water treeing in insulation)
Recommended for the Oil, Gas & Petrochemical sector.
