Holmes RBST-4 1020 over haul
Do anyone know the OEM part numbers of the followings.
10" Bearing Repair Kit containing :-
4 Main bearings,
2 location bearings,
4 main oil seals,
1 shaft seal,
4 Air deflector rings,
8 carrier locknuts,
2 flanged bras plugs c/w fibre washers
Many thanks,
Malith
RE: Holmes RBST-4 1020 over haul
Guys, I would appreciate if someone can help on this, with the parts list including part numbers
What I require is the bearing part numbers which is the most critical as in my first post.
