Could EM emissions prior to an earthquake affect Lithium-ion batteries?
Is this possible, or is this 'theory' nonsense?
https://www.youtube.com/watch?v=OLwMxcStTvI
-- Robert
RE: Could EM emissions prior to an earthquake affect Lithium-ion batteries?
Are you positive this cannot happen? If you are, I will take my video off of YouTube.
-- Robert
There may be some electromagnetic field changes prior to en earth-quake. Yes. But the order of magnitude is way below (hundreds or thousands of times lower, maybe million times lower - depending on housing and shielding effects) anything that can influence an Li-ion battery.
The battery in itself is probably a much greater risk than anything emanating from an earth-quake. Tropical thunderstorms produce much intenser electric and magnetic fields than an earth-quake can. And still do not threaten the battery.
Gunnar Englund
www.gke.org
Darrell Hambley P.E.
SENTEK Engineering, LLC
I cannot thank you enough for that. Most *d*ots refuse to learn. You are obviously not an *d*ot.
Gunnar Englund
www.gke.org
