Very Non-Standard Connection, Would like an Opinion.
Greetings, I am currently designing a moment connection between an HSS column and an HSS beam, I am forced into this configurations and although I would very much prefer to use W-shapes it is out of the question. Initially I tried to simply weld the beam to the column, but this lead to a myriad of problems such as plastification of the column wall, punching of the column wall and such. Currently I am trying to use stiffening plates to keep the wall of the column from deforming. However I know of no hand calculation to design or even estimate the design of this connection, this led me to rely on a FEA program (SAP2000), which I very much dread since I have to rely completely on the computer. What I did is model the connection without the siffeners and check that its behavior is as expected (miserable failure of the the connection to behave as fixed) and then I proceeded with my stiffener plates scheme. The general behavior of the connection is as expected, the HSS walls are no longer deforming as the plates give them considerable resistance. I am seeing very high stresses near the corners of the plates.. But this is a linear FEM Analysis so no stress redistribution after yielding is being accounted for. I will attach Images and printouts of the connection and would very much like to hear your input, If anyone can suggest a method for hand calculation I would greatly appreciate it.
RE: Very Non-Standard Connection, Would like an Opinion.
What about a simple calculation for direct shear in the plates and the stress in the welds, due to load running in the same direction of weld along the side of the HSS column?
The definition of a structural engineer: overdesign by a factor of 1.999, instead of the usual 2.
@civeng: Thanks, this is a very good idea. Another connection I must design has two beams meeting the column from opposite sides, this will most likely require a solution similar to the one you propose; a sort of "ring" plate around the column.
http://www.amazon.com/Design-Welded-Structures-Ome...
http://www.jflfoundation.com/ProductDetails.asp?Pr...
I believe that by extending the plate all the way to the lenght of the column sidewalls I will be effectively avoiding any of the failure modes of the HSS walls (except shear due to the weldings). Any thoughts on this?
Thanks, this forum and its users are a tremendous help.
Im trying to have the connection take a moment of 16000 kgf.m or 116 kip.feet, this beam runs 40 feet between columns but at 20 feet it rests over another beam that runs perpendicular to this one.
Here no one construct using this stiffeners (no one actually calculates the connections), so my client may think I am crazy when I give him the drawings, But theres no way this connection would take any moment without such stiffeners.. And I know for a fact that others assume this things to be fixed since they put haunches at the ends of the beams.. why else would you use haunches if not to increase the moment capacity at the the fixed end of the beam? My guess is that in reality this connections act as pinned and all that moment goes to the middle of the beam.. the only thing saving this guys is the 1.2DL and 1.6LL.
My hand calcs give a 45000 kgf capacity for a 1cm thick plate. Which I would be quite happy with (I need only about 35000). I try to test this on the FEM and Im getting stresses as shown on the attached picture. The deep blue color are stresses above the yield stress of the plate. I would like to somehow reconcile this results with my hand calcs... It seemed to me that when I use whitmore width for the plate yielding limit states I am assuming that all the yielding occurs along the whithmore width.. In the FEM This is not happening.. I have the "triangle" resulting from the whitmore width and the lines starting at 30 degree.. however the inside of the triangle is not yielding, while its perimeter is.. When we do whithmore width.. are we assuming that all the high stress is being redistributed from the point of force aplication "down" trought the plate?. The stresses in the picture occur when I apply a tension force of 40000 kgf. I would attempt a non-linear material analysis but this takes days to run. Basically I am just trying to validate my hand calcs so I can get rid of the FEM, which honestly I quite dislike using; but I dont want to ignore some important limit state by mistake.
The FEA looks about like you would expect it to look. And, your FEA printout/picture is telling you exactly what to do. Show us a couple dimensioned views of that connection, what size are the two members? What are the side pls. made of, that make up the hunch? Are they full height, top of beam tube to the bottom sloped surface, a bottom flg. in compression? You see that you can eliminate the middle stiff. pl., it doesn’t do much, except complicate the fab’ing. The bot. stiff. pl. might be placed at the same slope as the bot. of the hunch. And, you might try reshaping the top stiff. pl. so it takes the top tension out to the sides of the column tube, as a “Y” shaped (forked) tension field, not in bending across the stiff. pl. and the face of the column tube. Maybe that top stiff. pl. has an elliptically shaped cut-out, with the minor (major?) axis being the width of the col. tube, and running half way out the length of the hunch over the top of the beam tube to a half circle termination. This completely eliminates top stiff. pl. mat’l. in the yellow area of your latest picture. The outer edges of this top stiff. pl. should taper out on top of the beam tube about the length of the hunch, maybe a little further, as you’ve shown in your latest sketches. Try running something like this on the FEA and see what it looks like stress-wise. It should completely change the blue stress picture around the column corners. You will always see high stresses in your FEA, at corners, the multi-axial stresses kill you. And, we know this from our Theory of Elasticity study. We’ve known for a long time welding into and around corners can cause problems. But, a second angle of attack (a consideration), regarding the high stress areas in your FEA pictures is that, as long as a small region in a detail is well confined, by surrounding material or weld, a little yielding is usually not a big problem. There is still compatibility and just some redistribution of stresses/forces to the adjacent material. All of this needs a little more study, once we know the proportions/sizes of the connection and the members, and the loads and moments. I have to reread your last couple posts, and think on them a bit.
The book that AELLC suggested would be well worth your while, and Lincoln has several other good books on welding and weld design too, several of them by Omer W. Blodgett. “Design of Weldments” is one of them, with some different material in it. You have some really difficult welding conditions on this detail, and the FEA doesn’t show the potential problems in the welds. But some of them are at the same locations as the high stresses shown on the FEA.
Dik
Regarding the top stiff. pl.... The ears on my stiff. pl. (along the col. sides) would be 5-6cm wide, as your’s are, but they would be 25-26cm long (not your 22cm) before they started tapering into the 9cm beam tube top flg. I would increase your 18cm length to 24-30cm, further out onto the beam tube. At the column face, place the center of a compass at the face of the col. and at the center line of the beam and draw a half circle cut-out, the circle dia. is 20cm, the col. width. Except, I would like the cut-out to be elliptical in shape (minor dia. 20cm, major dia. 30cm), going out onto the beam a little further than 10cm. My top stiff. pl. is “Y” shaped. The large corner blue areas will go away, I’ll bet. I agree that tapered or square won’t make much difference on the stress flow in the top stiff. pl. but it is probably being cut out of a larger pl. by automatic cutting equip., so why not clean it up? Eliminate the middle stiff. pl. it just complicates the assembly. The bot. stiff. pl. should be tipped up about 30̊, made longer, and becomes the bot. flg. on the hunch, but it is cut square to fit the col. shape. Alternatively, the hunch could be cut from a piece of the beam tubing; then the stiff. pl. can be shorter, but I’d still tip it up to match the hunch slope.
Don’t weld around corners, stop welds on the flats of the tubes. The longitudinal welds btwn. the stiff. pls. and the corners of the beam tubes are really difficult welds to do well. Yes, you should include the load inputs from both the weld across the top of the beam tube and the two longitudinal welds btwn. the stiff. pl. and the corners of the beam tube, but do not try to connect them by welding around the corner of the pl. at the tube corners.
Make sure the architects won't have heart attacks when they find out the connection projects 50mm (2") beyond the face of the column.
Are the 3/4" fillet weld on both sides? Consider partial penetration of full penetration welds.
With such big welds, it may be worth checking for base metal rupture of the column (In the US, 5/8" is the maximum wall thickness for HSS8x8).
Check the beam for the concentrated load from the haunch. Stiffeners may be a good idea even if the beam can handle load. It could be informative to extend the beam past the haunch in the FEA model.
@dhengr: I understand now, well honestly I rather leave them as squares cause most likely this things will be cut using a hand-held torch (I live in the third world).. so any fancy tapering could come back and bite me in the rear. I will most definitely keep your suggestions about welding in mind.
@wannabeSE: Im pretty sure he will, but he is the one who wanted to have a 40feet clear span while supporting a steel deck. (this beam is supported on another beam at 20 feet.. just don't want to scare anyone thinking this thing spans 40feet on its own). I will have a pretty tough time designing the welds. I will keep everything you told me in consideration when designing the welds. I had the beam going past the haunch before.. I did see some stresses going over the limit but only in the vicinity of the haunch (no more than 2cm i would say) the rest of the web was fine, I will have to remodel and check again.. the problem is that I am applying the moment to the connection by using forces on the joint of the top web, directly above the haunch, so this will cause an artificial high stress in the haunch.. I will have to do a separate model for this.
I finally modeled the whole connection, it has a very large beam framing on one face and two more beams framing perpendicular to this one. Since I had to greatly expand the plates to take the other beams Im seeing much better stress distributions and my plate is only 1cm thick. However I am having a hard time finding out the proper way to get the design forces for the welds.. I mean I can probably get it with the FEA, but I would like to be able to do some ballpark estimating by hand. Would summing the tension forces (as vectors) coming from all three beams top flanges and using the resultant be an appropriate way? I am attaching my latest results, please comment.. this easily the weirdest connection I have ever designed..... Now I have to do two more.
I have a question.. If I size the welds to be enough to develop the rupture stress of the base metals, would this not preclude a failure of the welds? I mean, the hss or the plates would have to tear before the weld fails.
Dik
The connection in your sketch would be ideal, I believe the intention with this is to have the gusset transfer the load directly to the plate?. In my design the haunch loads the wall and then the wall loads the plate I believe (the wall tries to punch in and the plate restrains it). Yes, my intention with this stiffening plates is to allow the T and C force to travel from the front wall (the one to which the beam is framing) to the sidewalls without punching or deforming the front wall. The way I first envisioned the load path is: The beam flanges push and pull on the HSS walls, the walls then pull and push at the plates, which keep the walls in place and distributes the load to the sidewalls. Although I believe that by welding the flanges to the whole connected length of the beam I am transferring the load to the plates and then the plates transfer to the side-walls; however this is not the case with the bottom plate as I have it now, as the haunch bears on the wall without being connected to the bottom plate. I will definitely try to see if your connection detail is viable, I will have to talk with the welder.
This columns are loaded mostly by the moment coming from the beams.. their DC ratio is around 0.2 Compression and 0.8 Bending. I did not manually check interaction of axial and moment stresses with the shear coming from the T and C forces.. this is something I will have to do.
Here is just an example I googled of a wide flange beam in an HSS column (see figure 3). You can see that the entire HSS section is wrapped to ensure the integrity of its shape...
http://www.atlasconnection.com/profiles/blogs/hss-...
I think the design you show with stiffeners on the top and bottom is a holdover from wide flange theory where most of the moment goes through the flanges. This will not be the case I think with HSS and there will always be tearing and distortion.
The most important thing to reaching the full moment capacity of the section is to ensure the integrity of the entire HSS section shape. I think you will find that using gusset plates and stiffeners to create what is effectively a welded socket is the best way to do this even though it appears redundant and impractical in wide flange world. The benefit is that the connections should be very straight forward to design.
I have sketched what I think the connection might look like if the beam and column are the same width. If you want the column wider than the beam then the gussets and stiffeners will need to transfer the load not the HSS.
charlie brought up some good points and referenced an interesting site...
@SAIL3: I have not managed to get to this part as I was just requested to modify the structure (architectural reasons), this presents me with the opportunity of increasing the beam size and getting rid of the haunches, which actually lowers the moment on the connection by about 15%, And would simplify the connection. Im afraid that's as thick as the walls of these tubes get, the steel is Fy=50ksi and Fu=62ksi so it might hold, welding a diagonal plate from top ring to bottom ring could help in this (similar to what is done with W-Shapes) and I will also check the panel buckling.
Again thanks to everyone who has contributed to this thread.
